Ricoh Aficio 1035
  • tcypy1961
    • 773
    Ricoh Aficio 1035
    What is the difference between SP-7504-14 and SP-7504-64 on a Ricoh Aficio 1035? Don't both SP codes point to a bad fusing exit sensor? Could there be something else causing this problem? I replaced the sensor back in 2011. Other than this copier, I have only ever witnessed this misfeeding problem caused by the sensor once before, and I ended up replacing the copier because I didn't know it was the fusing exit sensor that was giving me my problem. When I looked up the misfeeds I noticed that the last ten misfeeds (all but three) were 014, and the others were 013. With that being said, wouldn't that conclude that my problem is 014? On another note, I did witness a paper misfeed and stop right before the sensor in the switch back assembly. Thank you for any help given.
  • allan
    RTFM!!
    • 5462
    Re: Ricoh Aficio 1035
    Mmm... remember those days. swap out the whole section, there are some nasty gates in there maybe the paper is going into the wrong path. But personalty i would set it on fire!
    Whatever
      • 37444
      -14 is a late or lead edge jam. The lead edge arrived late. -74 is a lag or trail edge jam. The trail edge lagged, did not leave, at the to long. The fusing exit sensor can fail in either or both modes because of damage to the sensor from prolonged exposure to heat.
      • bob marley
        • Jan 2012
        • 1339
        I think u need to replace the fusing exit sensor
        Live for yourself and you will live in vain. Live for others, and you will live again
