Savin 9935DPE
  • tcypy1961
    • 773
    Savin 9935DPE
    I installed a print option from Ricoh Aficio 350 to a Savin 9935DPE. However, when the board on the printer box is plugged into the BCU PCB the screw holes for the box don't align with those on the copier. Is there a difference in the BCU when the print box is installed? And is there a difference between the Ricoh Aficio 350 BCU, and the Ricoh Aficio 350e BCU? Thank you for any help given.
  • wester
    • Aug 2009
    • 113
    Re: Savin 9935DPE
    WOW you're going back aways. If my memory serves me well, and I wouldn't count on that, the controllers are different between the two versions that you're dealing with. I dig through the archives to find out for sure but that's a lot of digging.
    • sandmanmac
      • 3981
      Re: Savin 9935DPE
      Welcome back to 1998 everyone!
      While I can't speak to exact differences in fit and function of the circuitry, The "E" version had "Enhanced" functionality over the other, so I would have to conclude that the boards would not be interchangeable -even if they did fit.
      Please do everyone a favour and just bury that old beast
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        Re: Savin 9935DPE
        Their not the same boards............................................ ...............
        Ancient history...........................
        Mystic Crystal Revelations
        • slash
          • Apr 2015
          • 20
          Re: Savin 9935DPE
          You can use only NIC.
