Question about PostScript language
  • Faro
    • Sep 2012
    • 11
    Hello,
    We perform some test for a customer with a Ricoh MP 9002. The customer send a postscript file directly to printer. With the old device (a MP 9000) all work with no problem, but with MP 9002, it's odesn't work correctly.
    The processus is simple, all of postscript file have a MEDIACOLOR instruction (blue, pink, green) and de MP 9000 select the good tray.
    but In my Ricoh MP 9002, I just have "paper color 1" and "paper color 2" indication for tray, not all color, so when I send the file, they don't select a color tray ...
    Any idea ?
    Thanks for your help !
    Faro
  • slash
    • Apr 2015
    • 20
    Re: Question about PostScript language
    What do you mean directly printing? They print via ftp or printer driver?
    • Faro
      • Sep 2012
      • 11
      for my test : copy *.ps \\192.168.XXX.XXX\MFPNAME
      I try tu print with GSVIEW software (customer send me PS file)
      Faro
      • Moza
        • 232
        Originally posted by Faro
        Hello,
        Any idea ?
        Faro
        Why do you need to use "mediacolour" can you not simply specify the tray to use or maybe use "mediatype" instead
        • slash
          • Apr 2015
          • 20
          Faro
          It's SMB printing. I've never tried this way. I use SMB only when trying to resolve network printing issue. Check ftp printing and let me know.
          • Faro
            • Sep 2012
            • 11
            OK
            => Because I don't create the spool. It's a file generate bye a software and I can't change this configuration
            Send by FTP
            I try, but I have a 550 Permission Denied error ... (connect with standard admin account). I search a solution for this error, I update the post if I can
            NP
            • slash
              • Apr 2015
              • 20
              OK
              Send by FTP
              NP
              admin can't operate Ricoh machines. Make user test psswd test and put file on ftp server.
              • Moza
                • 232
                OK
                Send by FTP
                NP
                Think you will struggle unless you can edit the spool file, can you upload the .ps output file
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Try direct LPR printing:
                  From a command prompt:
                  lpr -S 192.168.xxx.xxx -P lp c:\filename.ps -o 1
                  The "S" and "P" are case sensitive. The "-o" is an "oh", and the last character is a "one". I think the "ell pee" is case sensitive, too.
                  The "-o 1" sets the binary option on.
                  Silly question: Does the MP 9002 have PostScript? Not sure if it's standard or optional on that model.
                    • 37482
                    PostScript is an option. I believe that the MP 9002 is one of the models that comes with built in PostScript emulation and XPS. PostScript emulation is not that great and XPS is not supported in the environment of terminal service and Citrix MetaFrame.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      If there's one thing I've learned over the years (especially here on CTN) is that what may be standard in one country may be optional elsewhere.
                      It's marketing at its finest.
                      • Faro
                        • Sep 2012
                        • 11
                        Ok, for do simple :
                        1. I have the postscript option (and yes, in France, it's an option !)
                        2. Print don't choose goosd tray with FTP Print
                        I think Ricoh postscript don't read "/MediaColor (blue)" command ... :/
                        Faro
