Hi
I have an MPC 8002 and it seems to jam all the time in the duplex unit, not the turn around section but the flap the falls in the middle. When I remove the paper it feels like its stuck with static and as the duplex unit is right underneath the fuser unit, I wondered if the heat can be the cause and any open else had this.
The jam's are all the same, one just going into the fuser, one sticking out of the registration roller and a couple going down to the duplex unit and this one stuck with static in the middle section.
Maybe I am looking to much at the wrong place but I can't think and checked sensors and all seems fine. Also changed feed tyres as I know this can be a problem with experience.
Many thanks
Tim
Many thanks
Tim
