Install hdd in ricoh mp 4500
  • Richards
    • Feb 2015
    • 19
    Hi! I am trying to install a hdd in a MP 4500 unit. I located where the HDD goes. I can physically see where to plug it in. Problem is how to get to it. Does anyone have an idea how to easily do this?
    The service manual I have doesn't cover this. (or I can't find it)
  • allan
    RTFM!!
    • 5462
    Re: Install hdd in ricoh mp 4500
    Making the HDD hard to get to is sometimes part of the security design.
    Whatever
    • Richards
      • Feb 2015
      • 19
      Thanks for the response. That does make since; although some of the literature about this machine was claiming that a removable HDD allowed users to know for sure that there were no files left behind. Anyway, I worry when I start pulling out stuff that I may not get it back right.
      • sandmanmac
        • 3990
        IF you actually have a service manual, the removal and replacement procedure is absolutely in there!
        IF you have any clue what you're doing, then it's about a 5 minute job to swap it
        IF the bracket that the HDD needs to be mounted to, in order to install it on the controller is missing, then you have a whole other issue to deal with.
        Either call a tech, or deal with the lack of duplexing, which seems to be the ONLY reason you're wanting to install it, based on you're previous thread
        • Richards
          • Feb 2015
          • 19
          Thanks and you are right. At this point I simply want to duplex. The HDD mounts inside a bracket and I see no way to remove this bracket with out pulling out a lot of stuff. I will check the service manual.
          • allan
            RTFM!!
            • 5462
            That's not for the customer to do.
            Whatever
            • Bantams
              • Jun 2012
              • 603
              See section 3.20 of the service manual there's even a nice little picture for you to colour in should take 5 mins max and that includes time for doing the picture .
              • Richards
                • Feb 2015
                • 19
                lol
                • ccchuah
                  • Mar 2009
                  • 159
                  without opening the back cover , just removing the side small plastic bracket , remove the two screw on the control board and just pull out the unit , the harddisk is mounted on this controller board
