C7501 "set fuser correctly"
  • mikadonovan
    • May 2008
    • 2931
    Hi, All. Can anybody tell me about fuser set? Is this a problem with the rear connector, or is there a set switch of some sort. I did a normal belt replacement on it, now it's down. This machine is really starting to piss me off.
    NEVER ASSUME ANYTHING
  • turbojetboy
    • Aug 2009
    • 279
    Re: C7501 "set fuser correctly"
    The fuser has a link wire accross 2 pins at the rear upper connector on the fuser itself. My bet is you have a problem on the fuser connector top rear just under the plastic top lid. Also note this link is set in 2 different pins depending on model range 7500 or 7501. Incorrect position or disconnection of this small link wire causes the message.
    • mikadonovan
      • May 2008
      • 2931
      Good call, Daryl. That's exactly what the problem was. I'll give you a rep bump for saving me from replacing the harnesses. Have a great day.
