Sc670 - mpc6003 / mpc5503 / mpc4503
  • Ricoh-ono
    • 339
    I had a machine that was throwing SC670 on startup. A ribbon cable and multiple boards later the SC code still existed. The problem was narrowed down to connector CN203 on the Imaging IOB board, then further narrowed to the "ID Chip" PCB:TCB (Yellow). The PCB:TCB was swapped with another color (Cyan) but the problem remained with (Yellow). After ruling out a pinched/shorted wiring harness, I remembered there is small "chip" on the toner bottle. So we finally removed the toner bottle (Yellow) and the problem went away entirely. Put the bottle back in and it the SC670 came back. Swapped the bottle with a good one and problem solved. There happened to be some sort of defective "chip" on this particular toner bottle. Hope no one ever has this problem, but if you do maybe this will help.
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
  • jmercado
    Re: Sc670 - mpc6003 / mpc5503 / mpc4503
    nice to know thanks for all the effort and time my Ricoh Brother.
    • SC542
      • Nov 2014
      • 7
      Thanks, sorry you had to go through all that [emoji3]
      • impetus73
        • Mar 2012
        • 75
        I had this same problem on a MPC2500, very frustrating to try to find the error. :-D Swapped the yellow toner, all OK.
        • Melvinp
          • Jun 2016
          • 9
          Thanks for the updates boys. Had a workmate come across this and he has replaced all PCBs on the parts lists.
          • Cipher
            It's not easy being green
            • May 2006
            • 1309
            Nice troubleshooting skills there.
            Can be a nightmare narrowing things down sometimes and understanding what exactly is the root cause of a problem.
            Especially difficult when you don't have the parts to try and swap around.
            • ESTANISLAOWENENTON
              thanks
              • francisco
                • Nov 2009
                • 168
                i had the same issue with MPc 2003, and it was the yellow toner chip.
                • aktasson
                  • Feb 2017
                  • 201
                  My first service with SC670-1 today on a mpc3003 (without faxboard, just with lower tray 3,4 pb) . Under the premise the problem could be caused by the toner, this is how i proceeded:
                  1. Machine power off and unplug the power cable -> after that pushed the power button for residual voltage
                  2. Unplug the network cable
                  3. Put all toner bottles out
                  4. Insert the firmware sd with package file
                  5. Plug the power cable and started the machine
                  6. Package update was possible without sc code
                  7. Restarted of the machine again without toner bottles
                  8. Machine starts regular and i installed the toners one by one.
                  9. Restarted with network connection
                  10. All the jobs from customers spooler were printed
                  • Batman1976
                    • Jun 2016
                    • 91
                    Quick question:
                    Was it Ricoh Genuine Toner or an independant supplier?
                    Rgds
                    • bob marley
                      • Jan 2012
                      • 1339
                      Than u 4 the info
                      Live for yourself and you will live in vain. Live for others, and you will live again
                      • aktasson
                        • Feb 2017
                        • 201
                        [ATTACH=CONFIG]29040[/ATTACH][ATTACH=CONFIG]29041[/ATTACH]
                        May can i ask you which 670-01,02,03 etc... occurred on the customers machine?
                        • Lagonda
                          • Aug 2008
                          • 1649
                          I'm chasing that problem right now, thanks for the heads up.
                          • aktasson
                            • Feb 2017
                            • 201
                            Here we go again, SC670-01. The toner trick does not help here in my case anymore. When the boards work properly green led is permament on and the red led of bcu board blinks permanently without breaks. When the green LED of IPU board blinks, the red led on bcu board blinks twice with a break between so there are possible communication problems bcu and ipu board. You see the two white flat cables. Pull both of them off (be very careful!!!) and put them on again on all marked sides. The eeprom on bcu I have also set out and put again on the socket. After this works the machine started without sc anymore.
                            • Ricoh-ono
                              • 339
                              Originally posted by Batman1976
                              Quick question:
                              Rgds
                              Yes. It was OEM.
