Looking for an odd ball fuser part for an MP C5501...
  • Foo
    • Nov 2009
    • 199
    My customer recently (I mean they've only had the machine a week...jeez) decided to remove the fuser from their MP C5501.
    They pulled and pulled and pulled until they broke both the pulls off the fuser cover.
    I tell them "now that's gonna cost ya". We all had a small laugh as I showed them again how to remove the fuser by first lifting the lock tabs...DOH.
    So I figure no biggie I'll call Precision and have them order me one... Ricoh P/N D0294103 Front Cover Guide: Duplex.
    Just a minute ago I call PR back and talked to my sales guy and he tells me Ricoh discontinued the part with no "newer" number to order.
    Now I'm kinda in a pinch.
    Any ideas where one of these could be found?
    Jeff
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Looking for an odd ball fuser part for an MP C5501...
    Unless ordered direct from Ricoh, you could use the same cover from old MPC4000 / 5000 or MPC3001 / 3501 fusers.
    On the newer 02 range, this cover is combined with the left and right covers as a single piece.
    • Foo
      • Nov 2009
      • 199
      But if they use the same part number I'm still out of luck.
      Jeff
      • Coptech
        worker drone
        • 460
        I didn't believe it but it truly is a z ranked part with no new number listed. No bulletins either. Two options. Call Ricoh parts and get the true story or buy a printer version fuser that would be a complete fuser with maybe a jumper wire needing to be changed.
        • Foo
          • Nov 2009
          • 199
          I don't have access to used parts or old machines to pick a part.
          So I need to find this part!
          Any help would be appreciated
          Jeff
            • 37480
            You do not need a used C5501. It is the same part on the MP C4000/C5000. The D029 indicates the product code where first used. I did a Google search and there a couple listings.
            • impetus73
              • Mar 2012
              • 75
              Pick it from a new fuser, then when it's time to use that fuser on another machine, move the cover from the old fuser in that one, over to the new fuser now lacking a cover. Problem solved :-D
                • 37480
                Your boss must enjoy spending money. You can get a used machine for less than a new fusing unit.
                • tufbnme
                  • 493
                  I have a few good parts machines, I can sell you the cover.
