message displays when I update the address book by WIM
  • tonnerboy
    • May 2011
    • 212
    Hello everyone.
    I recently had difficulties creating the address book using Web Image Monitor. If the device is in sleep mode a message displays that the device is being used by other functions and wont let me save it.
    For that effect I need to disable the sleep mode to add users in the address book.
    Is it a bug? Is there anyone that experienced it? Is there a firmware to fix it?
    (I have the firmware "Power saving" up to date.)
    • 37556
    Re: message displays when I update the address book by WIM
    To my knowledge that is the way it is. Change sleep mode setting from the control panel and work on address book. When through, change sleep mode back.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      And what model are you seeing this occur???????????? I believe slimslob is correct but you left out some information and went to the Ricoh generic card........FYI
      Mystic Crystal Revelations
      • tonnerboy
        • May 2011
        • 212
        You are correct!
        I am facing problems with the newest models (Ex: MPc 4503, MPc 2003, MP 2501...)
        Ok... if this is the procedure... I will continue doing it like this...
        Thank so much all
        • techsass
          • Dec 2010
          • 248
          They just updated the Scanner firmware on the c5503. One of the notes regards updating the Address Book.
          2. If user authentication is enabled, the address book cannot be updated from
          Web Image Monitor when the device is in energy-saving mode.
          I've got a recent install I'm going to on Monday that says she gets a "404" error whenever she clicks on the Address Book, but can browse everywhere else in WIM. I'm hoping this is why, but the previous Scanner update had the same fix listed. If not I'll try the Sleep Mode.
          • tonnerboy
            • May 2011
            • 212
            Well... in this costumer that I am facing this problem they have User codes enable...
            • slash
              • Apr 2015
              • 20
              I've never had problem while working with address book via WIM. I don't mean user activity. Show firmware ver.
              • techsass
                • Dec 2010
                • 248
                It's the 1st I've heard of this issue too, but obviously others have seen it. That's why I love this site.
                The new Scanner firmware is v01.07 or D1495560J.
                • tonnerboy
                  • May 2011
                  • 212
                  Copied from a bulletin;
                  1. If user authentication is enabled, the address book cannot be updated from Web Image Monitor when the device is in energy-saving mode. "
                  This modification came with the version 01.04
                  • tonnerboy
                    • May 2011
                    • 212
                    Hello everyone.
                    Already solved my problem with MPc 2003 updating the scanner firmware. But I have one more model that I am facing this problem.
                    Is there a fix for MPc305??? I can not find any firmware for this device...
