Ricoh Sp 4110/4310 developer
  • marvin_PL
    • Jun 2012
    • 24
    Hi all,
    first sorry for my english...
    I need to remanufacture some ricoh sp4310 / sp4110 toner cartridges. The problem is that I have to change developer, I know that I can buy compatible but the price is not satisfacting me. And I have a question, did someone use developer from copier to this cartridges? I'm wondering if developer from Af1015 will work, or AF 1045.
    thanks for any replies
  • maikel safwt
    • Nov 2014
    • 58
    Re: Ricoh Sp 4110/4310 developer
    The cartridges does not contain any developer but it has a toner that mixed with developer if you want to refill it refill with HP compatible toner
    • marvin_PL
      • Jun 2012
      • 24
      You're wrong. cartidge contains: toner & developer !!!
      • maikel safwt
        • Nov 2014
        • 58
        yes but mixed not separate
        • marvin_PL
          • Jun 2012
          • 24
          they are separate: look at Ricoh Aficio SP 4100 / 4110 / 4210, Toner Recycling Components, Toner, Chip, Drum for printers
          toner is mixing with developer while printing
          • hussam
            Engineer
            • May 2014
            • 11
            Try Developer Type 19, I think it will do the Job for you...
            Originally posted by marvin_PL
            Hi all,
