Savin SLP38c streaks on prints
  • InsaneIrish
    • Oct 2025
    I've got a Savin SLP38c that has started putting blue and yellow streaks at the top and wide green streaks at the bottom of all print jobs I send to it.
    I've tried to run the Color Registration Auto Adj. feature, and it comes back Failed.
    Is there something that I need to clean or replace to fix this?
    Any help is appreciated.
    thanks
  • sandmanmac
    • 3985
    Re: Savin SLP38c streaks on prints
    Yes.
    Replace Drum(s), and/or transfer blade, and/or transfer belt, and/or fuser.
    • InsaneIrish
      Originally posted by sandmanmac
      Yes.
      When end you say fuser. Do You mean the entire pullout unit?
      if that is the case I might be better off buying a new printer.
      • sandmanmac
        • 3985
        I'm saying there are several reasons a fairly old printer (or any printer for that matter) can have print quality issues.
        It's most likely the drums.
        Call a tech. (or not).
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2586
          The transfer belt unit is quite possibly the reason you can't pass color reg from this old dog.................. Don't spend much trying to fix this one...............my 2cents worth.............
          Mystic Crystal Revelations
          • Tonerbomb
            • Feb 2005
            • 2586
            Yes you are better off replacing the printer!!!!!!!!!!!!!!!!!!!!!!!!!!!!
