SCANNER FEATURE IS MISSING (MP 2501sp)
  • sharpmind
    • Sep 2009
    • 478
    The machine was having an error code SC 672-11. We replaced BICU, controller board and NVRAM. The error was resolved. We have noticed after booting up the machine, the scanner feature is not there. Why does it happen? Any solution?
  • blee
    • 51
    Re: SCANNER FEATURE IS MISSING (MP 2501sp)
    After replacing the boards and nvram you might need to go into SP 5-985 and make sure your nic card is turned on. If not then there is nothing to scan through so machine disables scan option.
    • Gift
      • Mar 2011
      • 2459
      Yup - there are a few SPs neccessary to check/adjust if you swap these parts - sometimes even if you do a NVRAM BACKUP/RESTORE. Try and use the factory SP sheet or get a non-default page from a similar machine. Not shure if the NV Ram swap was neccessary so you just might re-install the old NV ram and see what happens.
      • Vas
        • Oct 2017
        • 2
        I saw into another thread something about NIC board activation in service mode.
        • sandmanmac
          • 3981
          So you didn't read this just 2 posts above yours?
          BTW...this thread is nearly 3 years old
          • Polarbear
            • Feb 2012
            • 1070
            Almost good enough to be red wine, it is so old!
            Press the GREEN button!!
            • Vas
              • Oct 2017
              • 2
              Sorry guys! Don't shoot me!
              I wanted to help.
                • 37480
                Did you try putting the original NVRAM on the new board?
                • Iowatech
                  Not a service manager
                  • 3930
                  I wanted to help.
                  You want to help? Cool.
                  Just add some actual stuff that relates to fixing the problem. You'll be good to go then. Posts that don't do that even a little bit like yours frequently get the raspberry.
