Sc 901 on ricoh 2018d
  • Polo-022
    • Sep 2007
    • 481
    M/c with 157K clicks on counter. I replaced counter as for the cheapest solution, but not the most possible defect part, then i did an NVM Ram clear 5-801 with no positive result. I checked fuses on P.S.U also.
    Any experience about this, or suggestions? Should i have to replace BICU??
    What a date...today!
  • Jomama46
    • 2900
    If the pins for the counter ohm out at the BICU board then replace the BICU.
    CN122-6/7
    sigpic
    A+; Network +; PDI+
