SCAN TO FTP
  • sharpmind
    • Sep 2009
    • 478
    SCAN TO FTP
    Guys, do you have PDF/DOC tutorial on how to configure scan to FTP? I am not well familiar with this type of setup. Can you give me tips on how to set it up?
    Thank you.
  • tonnerboy
    • May 2011
    • 212
    Re: SCAN TO FTP
    Thank you.
    FTP to a server? Or using Filezilla?
    • sharpmind
      • Sep 2009
      • 478
      Re: SCAN TO FTP
      The client is asking me to configure scan to FTP (server). I am not familiar with the setup. Can you help me? I am also eager to know how to setup scan to FTP using Filezilla. I need tutorial on this. (PDF or DOC file)
      • allan
        RTFM!!
        • 5462
        Re: SCAN TO FTP
        Filezilla server works realty well in some setups. I got it figured out quickly.
        Search youtube there is a lot of tutorials.
        Whatever
        • nmfaxman
          • 1702
          Re: SCAN TO FTP
          Never touch a server without the Admin there!
          Leaves you open for a lawsuit.
          All they have to do is the simple google search.
          You show him where to plug in the FTP information on the machine through WIM.
          If the machine says complete, it is not a machine problem.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Re: SCAN TO FTP
            Filezilla is pretty simple to use, works well doesn't have to be on a server, but does need to be a running service on a workstation that is on all the time or runs at start up. When the host is off scanning is down.This gets you around the SMB v.x and authentication issues usually..............
            Mystic Crystal Revelations
              • 37375
              Re: SCAN TO FTP
              If they do not have IT and they want you to set up their server, talk to an attorney first and get a signed waiver from the customer. Otherwise you are going to get blamed for every problem that comes up on that computer for the next six months.
              • Tonerbomb
                • Feb 2005
                • 2589
                Re: SCAN TO FTP
                OH so true !!!!!!!!!!!!!!!!!!
                • gear13z
                  • Sep 2011
                  • 68
                  Re: SCAN TO FTP
                  hi sharpmind, hope this help, see attachment. keep sharing. cheers!scan to FTP setup.doc[ATTACH]29223
                  .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
                  • slash
                    • Apr 2015
                    • 20
                    Re: SCAN TO FTP
                    If you have admin or customer tells you to do it you have few options.
                    One of them is FileZilla (don't like), other is FTP server from IIS (from Microsoft) and the best is network hdd with ftp support. Why? Becouse nobody will screw it and you earn some money. Conf is easy (mass storage and MFP). All you do is:
                    Network HDD - checkbox on ftp option, add user and pass
                    MFP - WIM way - Addressbook, new - ftp - protocol to ftp - server name put ip address of network hdd - directory /
                    That's all. If you use software option and don't know to much about IT, you will get probably a lot of problems.
                    • Elmo
                      • Feb 2010
                      • 541
                      Re: SCAN TO FTP
                      ricoh scan to ftp
                      I Used To Live To Fix Things Now i Fix Things To Live
                      • sharpmind
                        • Sep 2009
                        • 478
                        Re: SCAN TO FTP
                        Originally posted by gear13z
                        hi sharpmind, hope this help, see attachment. keep sharing. cheers![ATTACH=CONFIG]29223[/ATTACH][ATTACH]29223
                        My friend and I had tried to configure scan to FTP using Filezilla server and it works in our office.We just configure one user only.My questions now are: What is the advantage of using scan to FTP instead of using scan to SMB? How many users can be configured in scan to FTP? How the users can retrieve their scanned documents?
                        • tonnerboy
                          • May 2011
                          • 212
                          Re: SCAN TO FTP
                          You will use it in the very near future. Maybe tomorrow I give you a quick example. Scan-to Folder do not work in Windows 10 and There is no firmware from Ricoh to fix it (yet...)
                          Even in new devices like Metis the SMB is not working in Windows 10.
                          (I have tried with no success)
