Ricoh Sp c811 have a sc 548
  • maikel safwt
    • Nov 2014
    • 58
    Ricoh Sp c811 have a sc548 i tried to change everything: Fuser,IH inverter board,I/O board ,interface board, Power Board , Fuser motor
    and no response .
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh Sp c811 have a sc 548
    That is a level "A" code. It must be reset using SP 5810.
    NEVER ASSUME ANYTHING
    • maikel safwt
      • Nov 2014
      • 58
      I did it in every step I did
      • sandmanmac
        • 3964
        SC 548 Fuser unit rotation error - check condition of star wheel actuator
        SC 548 Fuser unit rotation error - check/clean/replace rotation sensor (SP5-803-34 to check)
        SC 548 Fuser unit rotation error - sensor out of holder, reinstall
        SC 548 Fuser unit rotation error - sensor bracket bent , check and repair
        • turbojetboy
          • Aug 2009
          • 279
          and no response .
          Most likely its the sensors upper left side behind small upper cover that detect fuser and ferrite rotation. Replace with the modified types Aw020190. 15 minute job.
          • maikel safwt
            • Nov 2014
            • 58
            you mean the "C" one in the photo?
