MP C2500 SC995
  • ABS tect
    • Sep 2013
    • 511
    MP C2500 SC995
    I replaced the print card from an mp c2500 with one from a different machine, it fired up, then i switched the original print cards to the original machine. And now i am having a sc995 error code and it says that it is not the original controller board, but it is. So i tried reformatting the HDD with 5-853-001 and nothing is working. Still have the sc995 code, any suggestions?
  • sandmanmac
    • 3981
    Re: MP C2500 SC995
    GG shows this relating to your issue, but I don't have the TSB. Maybe someone else will weigh in on it for you:
    SC 995 Controller mismatch error - see TSB# 003 "Technical Tips" #4 Swapping PCB's between machines
    • ameritech
      • 96
      Re: MP C2500 SC995
      SC995
      [Cause]
      The IOB is faulty.
      [Resolution]
      Replace the IOB.
      When using an IOB that you removed from another device, refer to the notes below.
      [IOB Replacement Notes]
      • The new service parts AT-C1a/C1b can be used in common
      • AT-C1a cannot be used with an IOB that AT-C1b is attached to
      • AT-C1b cannot be used with an IOB that AT-C1a is attached to
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        Re: MP C2500 SC995
        IF you only swapped the SD card over between MPC2500's it's probably a serial number mis-match.
