RICOH Aficio SP C242 PnP Name 0x?
  • druk-serwis
    • Sep 2014
    • 7
    Hi. Can anyone see what is the PNP for RICOH Aficio SP C242? It`s in service mode->engine maintenance->PnP Name It looks like 0x??
  • logrady2331
    • Feb 2011
    • 301
    Re: RICOH Aficio SP C242 PnP Name 0x?
    What?
    • druk-serwis
      • Sep 2014
      • 7
      Zapodaj.Net - Darmowy hosting zdj
      Sorry that its upside down.
        • 37452
        Originally posted by druk-serwis
        [ATTACH=CONFIG]29252[/ATTACH][ATTACH=CONFIG]29253[/ATTACH]
        I am getting "Invalid Attachment specified. If you followed a valid link, please notify the administrator" for both of your links.
        • druk-serwis
          • Sep 2014
          • 7
          Now everything should be ok ;-)
            • 37452
            Looks to me like an OS error code. Google 0X13.
            • Iowatech
              Not a service manager
              • 3930
              As I'm not trained on this machine, what follows may be a waste of time.
              That being said, this sounds a little like druk-serwis is asking about the Plug and Play name for that machine.
              (On the older printers that I do work on, the Plug and Play setting is in the Engine service mode, somewhere near the end of SP5. But I've never seen it listed like the pictures druk-serwis shared, so I'm not sure.)
              Then again, the Plug and Play setting has no real operational effect on the machines I've worked on, so I'm probably way off base. Sorry.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                If this machine has a Ricoh controller (sorry, I don't remember right now), and has a WIM, it will be at the top of the list under "device info".
                There are times this exact name, which is case and space sensitive, is needed, such as when using DMNX to deploy a firmware package; the firmware packaging tool needs the exact name to function.
                Outside of that, you could always use DMNX Lite (a free download), or the now obsolete Smart Device Monitor for Admin, if you still have a copy.
