Ricoh MP W3600 streak
  • Hadster
    • Aug 2011
    • 264
    I haven't worked with wide formats for a couple of years (FW240) so please be patient. I have what looks to be a simple problem but not sure what is the cause. The machine has 40k ft. on it with this light streak down the side and a little background at the top. Every thing in machine is clean. Developer rolling around evenly. Optics clean. Corona's clean. Any idea's would be appreciated. Let me know what more info you might need. Thank you so much!
  • jdzr
    • 125
    Re: Ricoh MP W3600 streak
    I know you said everything is clean but it really does look like it needs a new charge wire and also make sure you clean the bottom side of the optics real well although it does look like the wire should take care of your problem. Have fun with the wire and good luck.
