SPC430DN SC452
  • GeorgeBest
    • Jul 2009
    • 526
    SPC430DN SC452
    Hi,
    Error SC452 is returning on this machine. (Also SC400 sometimes)
    Checked sensors, cleaned the ID sensors, swapped the entire transfer unit . . .
    Sometimes the machine works fine, but for only a small period.
    some one a clue here ?
    Just a couple of machines in the field.
    Thanks in advance
  • sandmanmac
    • 3981
    Re: SPC430DN SC452
    Originally posted by GeorgeBest
    Hi,
    Let's be clear.....You understand that this is a transfer roller error, and not a transfer belt error ??
    • GeorgeBest
      • Jul 2009
      • 526
      Re: SPC430DN SC452
      I understand . .
      swapped the roller also.
      • sandmanmac
        • 3981
        Re: SPC430DN SC452
        I understand . .
        Also? So at some point you weren't aware then...because it was never going to be a belt issue.
        So then, it's either the contact sensor or the motor.
        • GeorgeBest
          • Jul 2009
          • 526
          • sandmanmac
            • 3981
            Re: SPC430DN SC452
            I must admit, I overlooked your inclusion of SC400.
            You've only cleaned the ID sensor, but it may need replacement, otherwise likely the BCU.
