Vetical band on A0 print out
  • daddy boat
    • May 2015
    • 4
    A format copier ricoh af 240w which am repairing prints a vertical black band line of about 1 to 2 inches,I have serviced the LPH but still the problem is there.Does this machine have a laser unit?I need an urgent help ,thank you.
  • mikadonovan
    • May 2008
    • 2931
    Re: Vetical band on A0 print out
    Sounds like the corona wire cleaner is stuck in the middle.(it happens) Try cycling the corona wire cleaner in sp mode first. If no joy, the procedure for removal is involved. You need a manual. Lines can also be caused by worn fuser rollers, a dirty scanner glass, fault in the PCU, etc.
    NEVER ASSUME ANYTHING
    • rsyarcia
      Hair Straightener Tech
      • 711
      If the LPH is defective it should be white lines not black. MIka is right maybe the charge corona cleaner didn't moved to home position. It is using LPH not laser.
      Nobody is perfect..
      • daddy boat
        • May 2015
        • 4
        Thank you very much for support.
