Ricoh Mp C305spf/ Drum replacement
  • cucuklotz
    • Mar 2007
    • 611
    Hi Im replacing the yellow drum unit tomorrow,first time Ive done this on this machine.I didn't really see anything specific in service manual.Is there anything I need to do when replacing this drum. Thanks for any help Andy
  • cucuklotz
    • Mar 2007
    • 611
    Re: Ricoh Mp C305spf/ Drum replacement/Follow up
    Hi I took a closer look manual and saw procedure for replacing other units(other than black I guess).It said to output the smc logging data with SP5-990-004 and ck counter values.and from there it talked about SP7-804,SP7-853.It gets very confusing and Im lost.Can someone please helpmake this simpler .Im very limited on Ricohs Thanks Andy
    • jonhiker
      • 661
      replacing the y unit is the same as the k unit.
      • Zaxxon
        • 608
        If this confuses you, then wait until the toner supply need replacing
        Please start you post with brand, model, problem.
        • cucuklotz
          • Mar 2007
          • 611
          HI,You said replacing the y is the same as replacing the K unit.Can you walk me thru which SP s I need to run? Thanks Andy
          • Moza
            • 232
            Replace the item and then set the corresponding in SP 3701 to a "1" switch device off and then on
            • cucuklotz
              • Mar 2007
              • 611
              Hi Thanks for the help.I replaced the unit and and reset in 3701 and it took.I replaced the yellow drum unit,so I reset the one that said drum unit,there was a reset for developer and the pcu only,but I figured since they are in drum unit,the reset for unit would cover all bases.I hope Im right Thanks Andy
              • impetus73
                • Mar 2012
                • 75
                ONLY reset the PCU drum unit, NOT the PCUD unit!!! PCUD = PCU + Dev. If you reset the whole unit, as you did, you also reinitialize an old developer.... Either it works, and your lucky, or you will have to replace the dev unit soon, due to bad print or toner spilling.
                • Moza
                  • 232
                  Seen as there is only a PCDU available for this device and NOT separate Drum unit and Dev its fine
