Ricoh MP301 fusing frame part number?
  • Polarbear
    • Feb 2012
    • 1070
    Hi everyone
    I have a bit of a headache here. I need a part number for the fusing frame that holds the hot roller on the MP301.
    I find the p/n for the pressure roller and they even draw the hot roller frame in the 3d parts listing, but there is no part number. Does such a number exist? I don't feel like paying for a complete fusing unit if I can avoid it.
    Any help will be greatly appreciated.
    Press the GREEN button!!
  • Sashko
    • Oct 2009
    • 110
    Re: Ricoh MP301 fusing frame part number?
    Hi,
    FRAME:FUSING D1274102
    Not available?! Ask Ricoh
    • Polarbear
      • Feb 2012
      • 1070
      Originally posted by Sashko
      Hi,
      Hi
      Where did you find that? As I checked again, the European manuals don't have that part number.
      Could you please send an image of the parts manual that has that number?
      Thanks again!
      • Sashko
        • Oct 2009
        • 110
        Deduction.
        Previous model has the part number for the fusing frame B1294102.
        I changed the B129 to D127 (machine model name) and checked on Ricoh sites.
        I'm not sure, but maybe B1294102 has a same construction as D1274102.
        • Counsel
          • Aug 2011
          • 530
          D1274102 does not exist that I can find on ricoh or parts suppliers, the old B1294102 that I know of does not fit in this machine the 301 fuser is slightly different, I could be wrong because I haven't attempted a swap of parts but the lower frame, rollers, exit plate and pawl are all different, you cant swap the exit pawl from the old style to this fuser they are shaped differently, the frame is different due to the change in the gate guide that flips outward. So I would say your stuck getting a new fuser, its likely the part is just not available *yet but might be added later.
