richo 4500 error
  • feroo666
    • Dec 2014
    • 23
    richo 4500 error
    can any one help me i need change IP when trying i see this note
    (( you do not have the privileges to use this function ))
    please help me
  • JonManchester
    Technician / Shop Manager
    • Aug 2013
    • 101
    Re: richo 4500 error
    You need to log in to the copier through user tools, Most of the time its Admin and no password but if that doesn't work its anyones guess.
    Live for something or die for nothing.
    • feroo666
      • Dec 2014
      • 23
      i try avery thing but no slotion
      • mikedci
        • Jul 2010
        • 227
        the a in admin should be lower case(if its still set to default)...did you try that?
        • feroo666
          • Dec 2014
          • 23
          I can't access to any thing in machine
          • hossam
            • Aug 2010
            • 70
            Swap rams inside controller board,
            Make sure to print out none default programs before doing that because everything will be reset. Good luck
            • feroo666
              • Dec 2014
              • 23
              Tehya masr ya ostaz hosam
              please can you explain the steps to do that
              • sandmanmac
                • 3928
                Buy A Manual.... and read it!
                If you're not prepared to invest a few dollars, then GOOGLE IT! Lots of FREE DL Options!
                • tufbnme
                  • 493
                  PM me, I'll walk you through it without replacing the NV Ram or clearing the memory.
