830DN ceramic converted. Track marks/blemmishes
  • harrishabitat
    • Jun 2015
    • 7
    Now that we finally got our networking issue solved we now have this issue with these track marks/blemishes showing up in the print. There are spaced out about every 1 1/4" through all 4 colors. Heaviest in the blue. Have already changed the rollers as well as just changed the fuser unit and roller there as well.
    And ideas of what this can be? We can't seem to find it inside the printer.IMG_20150608_100158.jpg
  • Counsel
    • Aug 2011
    • 529
    Re: 830DN ceramic converted. Track marks/blemmishes
    My first guess with white splotches would be the paper transfer roller which should come in the maintenance kit with the fuser, if that doesnt do it then i would suspect the transfer belt unit. At first glance I would normal say developer mag roller but you normally see that with one maybe 2 colors close to PM, all 4 doing it after replacement I would suspect Paper transfer roller first and its cheapest to replace vs the ITB.
    • harrishabitat
      • Jun 2015
      • 7
      Ok thank you, I will give that a try
