I have gestetner 735 it give me password at power up and in system program i can not clear them by clear memory (all) or clear access code how can i solve these password ?
clear password
Press the user tools button, hold down the # key and press System Settings on the touch panel. This will ask you if you want to reset to the default settings. This should turn off the user codes.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
fourwinns
go to user tools and then login at the top right corner as supervisor. This will then allow you to only access and change the admin password. After changing to password you will be able to login and reset yor optionsComment
