MP 6000,6001- limiting user copies, is this possible?
  • Creedmoor
    • Jul 2025
    Can you lock out a user when they have reached a global copy limit? machine is setup withuser codes. The customer swears they had the capability on their last copier same model(?). I cant fiind it anywhere. one guy told me it was possible with the right firmware version. I can find that either.
    Thanks for the help
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: MP 6000,6001- limiting user copies, is this possible?
    this is possible with newer
    models like mp 6002.
    Nobody is perfect..
    • teebee1234
      • Jul 2008
      • 1670
      If they had it on their last machine and it was the same model then the had to have had equitrac or something equivalent added on. As rsyarcia stated, the newer models have this feature.
      • techsass
        • Dec 2010
        • 248
        There's an app called USER ACCOUNT LIMIT on the TSRC site under Solutions / Security that I setup on an MPc5000 a few years ago. It's a JAVA app that lets you set limits on the user accounts.
        From the FAQs:
        16. Will I have to fill out a custom form to get the files? Yes, RAC (Ricoh Americas Corporation) and RCL (Ricoh Company Limited) need to know how often the item is being used and for what models.
        17. Where can I find the firmware and installation instruction?
        Answer: On the TSRC website, under solutions, management
        solutions.
          • 37431
          From the FAQs:
          solutions.
          I have a couple of schools using this app.
