MP C6502 D2 Fuser Jam code
+ More Options
Posts
  • Timmytronic
    • Oct 2010
    • 249
    Hi
    I have a MP c6502 with d2 fuser jam code,
    Spent 8 hrs on it yesterday, we have replaced all parts in that area from another fully working machine still does the same not sure if it is a software or board issue?. The parts also include the coiled cable which is at the back of the unit.
    If anyone has had this it would be great
    Many Thanks
    Tim.
  • Zaxxon
    • 608
    Re: MP C6502 D2 Fuser Jam code
    I feel with you... what jam code nr?
    Please start you post with brand, model, problem.
    • Timmytronic
      • Oct 2010
      • 249
      Hiya
      What do you mean? :-)
      • Zaxxon
        • 608
        Like j005 ish ;-)
        • Franco Vorster
          • Sep 2016
          • 6
          Same problem. Displays jam at D2. Bulletin says to replace eprom on BCU, but this did not help. Jam code = J001
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            I've had the D2 lever break off the sensor actuator on the under side of the lever, Thanks to the "church lady". replacing the D2 lever fixed the constant D2 jam that would not clear. Mine was on the c5100, same part.
            Mystic Crystal Revelations
