D013/ R5000
  • Dshaffer
    • Jan 2015
    • 12
    D013/ R5000
    We have a machine giving us this lead registration problem only on the second side of the page: Anyone have any ideas what could cause this?
  • Dshaffer
    • Jan 2015
    • 12
    Re: D013/ R5000
      • 37480
      Re: D013/ R5000
      USER TOOLS
      COPIER/DOCUMENT SERVER
      EDIT
      1 Sided -> 2 Sided Auto Margin. Default is 5mm, 0.2 inches
      • Dshaffer
        • Jan 2015
        • 12
        Re: D013/ R5000
        USER TOOLS
        EDIT
        I mi tried to adjust this higher and lower. No change in the reg issue. It happens out of all trays
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          Re: D013/ R5000
          To isolate the problem on your Mpc 4000/5000 we need to know the following---- Is it just happening when you use the Doc feeder to make 2 sided copies or also happening when printing 2-sided docs from the computer? If 2-sided printing from the computer is ok......might be a doc feeder issue.
