error code 672 - aficio 2060
  • nokia88
    • Aug 2009
    • 72
    Hi everybody,
    i have afc 2060 e-code 672, when turn main sw. on, all of motors did not test for few minutes & code 672 displayed..
    action: tried to replace some parts: HDD, RIMM, control panel, cables (from panel to controller), some boards. (pls. see file attached for more detail)...
    any idea else to help me ???
    Tks.
    • 37502
    Re: error code 672 - aficio 2060
    From Goose's Guide:
    SC 672 controller start up error - reseated controller board to motherboard
    SC 672 controller start up error - replaced motherboard and ram as a set
    SC 672 controller start up error - replace HDD
    SC 672 controller start up error - replace controller board PSU
    SC 672 SC 672 - replace mother board B1405218
    SC 672 controller start up error - optional 256 meg memory dimm bad
    SC 672 Controller start up error - replace ethernet pcb
    SC 672 Controller start up error - set sp mode 3904 to 1
    SC 672 Controller start up error - replace controller board
    SC 672 Controller start up error -replace fuse 103 after fixing short for paper height sensors in tandam tray one.
    SC 672 Controller start up error - replace NVRAM
    I would try the fuse first since since the power LED is not coming on.
    • trc
      • Jan 2007
      • 95
      Try using Boot SD Card type 2051.....
