MP1100 Fuser setting error
  • daveyball
    • May 2009
    • 314
    Hi I've got a MP1100 that says fuser unit not set error, with the doors open. When I insert the fuser unit, I get " paper output unit setting error" when the doors are closed with the fuser in. All wiring look OK, suspect IO board.
    Any Ideas
  • rthonpm
    • Aug 2007
    • 2860
    Re: MP1100 Fuser setting error
    There's no paper wadded behind the fuser or wedged in the connector to the main board? I've had a few of the bigger machines throw all kinds of errors thanks to paper bunched into the fuser connector.
    • daveyball
      • May 2009
      • 314
      checked for that, the fuser not set with doors open, is the main puzzler, didn't this model have issues with the main door interlock switches?
