SC 204 Ricoh MP 6001
  • KozyraPL
    • Jul 2025
    [Error Code] SC 204 Ricoh MP 6001
    As the topic . I changed my DC Polygon Mirror Motor and checked the Motor Control Board on another machine. You can print approximately 10-15 pages and pops up an error . Any ideas ?
  • KozyraPL
    Re: SC 204 Ricoh MP 6001
    Nobody not met with this problem??
      • 37491
      From Goose's Guide:
      D062/D063/D065/D066 SC 204 Polygon mirror motor error 3 - IPU defective
      D062/D063/D065/D066 SC 204 Polygon mirror motor error 3 - Polygon mirror motor defective
      D062/D063/D065/D066 SC 204 Polygon mirror motor error 3 - check harness and connections
      D062/D063/D065/D066 SC 204 Loose ground spring on rear of D062 2261 PCU: Lower Ass'y, re form spring or replace.
      I would check the harness and ground spring before swapping IPU.
      • KozyraPL
        From Goose's Guide:
        Thank you for your response. Check it out after the weekend . I searched on different sides of this may be it . We think the cause may be a fan or ozone filter ?
        I remembered that there was an error SC 204*.
        You know what that can mean ?
