how to print directly from a usb stick to machine
  • pukiro
    • Feb 2011
    • 59
    [Misc] how to print directly from a usb stick to machine
    Hi
    i have a mpc 4500 and mpc 5000, and my client wants to print directly via usb stick (pdf). I was told to install VM card Type C and the usb extender... but no joy...
    can anyone help??
    thank you in advance for your help.. much appreciated
    Ronak
  • impetus73
    • Mar 2012
    • 75
    Re: how to print directly from a usb stick to machine
    I don't see what the VM card is needed for, but you will need the USB card, and a USB/SD host extension, that you mount on the side of the operating panel. Not sure if MPC4500 has this, or if it was MPC2800 and newer...
    • pukiro
      • Feb 2011
      • 59
      i have the usb card installed and have the host extension... connected them.. but cannot see option to print via usb on the print option...
      • tonnerboy
        • May 2011
        • 212
        Hello.
        EDIT: It will not be possible... This device will just scan-to-usb/SD with that optional...
        (Even thaw I am not 100% sure I remember installing in a MPc2050 and it just scan...)
        • turbojetboy
          • Aug 2009
          • 279
          I think the Usb/Sd option box for the models you are talking about is only for allowing scanning to Usb/Sd card. I could be wrong here, but I have not seen these earlier models support printing from Usb/Sd.
          • impetus73
            • Mar 2012
            • 75
            Only solution, is to setup a laptop next to the machine, and allow them to print from the laptop using a memory stick in the USB port of the laptop.
            • tonnerboy
              • May 2011
              • 212
              This optional (Usb/Sd option box) it was usually associated an optional pictbridge.
              Only then it made sense ...
              • Klydon
                • Mar 2009
                • 243
                Also be aware that even on new machines, what type of files the machine will print is very limited. PDF and JPEG are supported. Anything that you would need a license for (like a Word file) will not be able to be printed in that fashion.
                • pukiro
                  • Feb 2011
                  • 59
                  thank you all for your help!
