I'm not sure on the exact cross for the Gestetner, but if it's analog check the main charge. If it is digital, check for the dv roller not turning, dv bias, and lack of transfer.
If it is digital, stop the copy process while the 'image' is being put on the drum, and see if there is a latent image on the drum. That will usually tell you if it is a transfer problem or not.
Many times, a dv roller will not turn, and it can take a while to figure out. Once you've seen it enough, you can better recognize the CQ problem.
Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
