Ricoh MP C4500
  • Reed
    • Feb 2011
    • 261
    Ricoh MP C4500
    The color registration is off on this Ricoh MP C4500. I can go into the maintenance menu after pressing user tools/counter button and perform the color calibration page but when I try to perform the color registration the machine runs for a few minutes then stops and and says it is unable to perform adjustment. I have attached a sample of the color calibration page and a sample of a color copy. The machine also has the same problem when executing a print job. Any help would be appreciated. Thanks in advance.
  • Iowatech
    Not a service manager
    • 3930
    Re: Ricoh MP C4500
    For what it is worth, it would probably be better if you post your question here:
    http://www.copytechnet.com/forums/ri...tetner-lanier/
    That's where the vast majority of people with Ricoh experience are.
    Good luck!
    • Mike R
      • Jul 2015
      • 4
      Re: Ricoh MP C4500
      I have seen this issue a couple of times and changing the developer in all units fixed the problem.
      • jam-o-matic
        • Oct 2012
        • 72
        Re: Ricoh MP C4500
        Run the Line Position Adjustment in SP's. I have also had good luck toning up, if the color bars are too light or splotchy (paper can also be a factor).
        • Phat Albert
          Re: Ricoh MP C4500
          True that SP Mode is the way to solve this isuue SP Drum: Line positioning adjusment
