how to install a new copier ricoh 7502
  • yasir
    • Mar 2007
    • 19
  • yasir
    • Mar 2007
    • 19
    Re: how to install a new copier ricoh 7502
    i am familiar with xerox ,i think there is plastic near the Ibt belt under the drum just to take the screws?and remove it
    also do we need to write data as defult
    • TonerMunkeh
      Professional Moron
      • 3865
      Easiest method to follow is the installation instructions in the service manual.
      Hit it.
      • yasir
        • Mar 2007
        • 19
        i do not have service manual mind you please put attach for this
        • Gift
          • Mar 2011
          • 2459
          You might ask for a manual and latest firmware at the place you bought the machine (and parts in the future).
          • Ollie1981
            Toner Monkey
            • Mar 2008
            • 417
            Plug it in, turn it on, load it with paper and toner, then copy till your heart's content.
            • techsass
              • Dec 2010
              • 248
              When you say "INSTALL" what condition is it in?
              New out of the box there is no Developer, etc. in the machine. The shipping safety stuff you have to remove should have tags attached.
              If all of the tape & tags have been removed already, it's probably mechanically ready to go. You should be able to use the Operators manual to learn how to setup the networking, user codes and what not.
              If that's the case let us know what you're trying to enable/assemble & somebody will give you all kinds of helpful hints here.
                • 37533
                For point of clarity, are you talking about the B/W MP 7502 or the color MP C7502? If it is the MP 7502, then it is pretty much the same as all previous high volume, 60 - 90 page, machines. If you are talking about the color MP C7502, if do not have any training on the pre-production color machines you are better off not touching it.
                • Gift
                  • Mar 2011
                  • 2459
                  Even with thraining I try to avoid the C model
                  • yasir
                    • Mar 2007
                    • 19
                    yes this the case there is some plastic and tapes near the ibt ,need to connect the ibt ? or it is already connnected ?
                    the default settings are already installed?any need to activate it? all are done through the pannel display?
                    • bob marley
                      • Jan 2012
                      • 1339
                      yes this the case there is some plastic and tapes near the ibt ,t?
                      Never try to install a new machine without knowing the installation procedures
                      Live for yourself and you will live in vain. Live for others, and you will live again
