MP C300 - Parts nr needed (SC452)
  • Zaxxon
    • 608
    Hi
    I am in need of parts nr for Ricoh MP C300
    PTR motor (fig.12)
    PTR contact sensor (fig.7)
    I've got the partsmanual, but sadly lack the skills to find them
    Thanks!
    Edit: The picture is from the point to point manual
    Please start you post with brand, model, problem.
  • Zaxxon
    • 608
    Re: MP C300 - Parts nr needed (SC452)
    Anyone?
    • Debs1964
      • Oct 2010
      • 1693
      I can see your problem!!
      I THINK the motor is M0281031, found under Main Drive U015 Item 68
      The sensor is even trickier, and the only one I can find in that area is AW010118, found under Image Transfer U010 Item 8, but the description is Paper Feed Sensor, so I'm not convinced I've found the right one.
      Sorry I can't be any more help
      There are 10 types of people in this world, those who understand binary maths and those who don't
      • sandmanmac
        • 3983
        I was just banging my head against the wall looking at the 3D catalog myself, in order to try and help out.
        I came up with the same part number as Debs for the Motor, but I think the sensor is GW020020.
        It looks like a standard photo interruptor, so I'm sure you have one of them lying around your shop anyway.
        These stupid 3D catalogs are brutal! It looks like Zaxxon's is a 2D version
        • Debs1964
          • Oct 2010
          • 1693
          You're probably right on the sensor, I really wasn't convinced by my number, I'm using the 2D manual too, your part number wasn't where I was looking
          • Zaxxon
            • 608
            Thanks Debs
            I've been looking some more, downloaded new 3D manual too, with no luck. These manuals are really tricky or am I just getting old?
            Please give us the line-art manuals back.
            Nice evening to you all.
            • Zaxxon
              • 608
              Thanks sandmanmac
              Will order the part and perhaps the real machine is easier to figure out tham these crappie manuals...once again thanks for your effort both.
              my 2D manual is for the point to point only, sadly not the part manual itself...
                • 37553
                I have found that the 3D parts catalog and the Parts Finder are great as long as you already know the part number.
                • Zaxxon
                  • 608
                  In the partscatalog every motor is just call DC motor...heck I know it's a DC motor, haven't seen an AC motor in a copier for decades
                  • HDSB
                    Field Tech
                    • Feb 2013
                    • 64
                    have you managed to fix this? Have SC452 on an MPC305
                    • Zaxxon
                      • 608
                      I replaced the ptr lift motor, but now I am on hollyday and don't know if it was solved as the error was periodic.
                      I have a MP C 305 too throwing sc452... Changed the Ptr position sensor with no luck... Can't really figure out how this mechanism working. Went back and did some lubrication at the Ptr sektion but do not know if this worked either.
                      please let me know if You figure it out.
