Hello Folks!
Can you diagnose this problem?
Attached is a PQ sample from the unit. You will notice the terrible banding vertically which apparently has no resolution with this printer.
Most notable though, width wise you will notice these ugly lines where there is almost less paper. It gives the whole printed page an almost bubbly look with white lines though it.
This is printed on Blazer Gloss 80lb Cover, and no matter the print setting the result is the same. This problem developed after a run of about 30,000 impressions.
Any suggestions would be appreciated!
