Gradient pale problem in MP C4500
  • maikel safwt
    • Nov 2014
    • 58
    Gradient pale problem in MP C4500 i try to change the transfer and the side separation roll no change
    Thanks alot
    • 37379
    Re: Gradient pale problem in MP C4500
    Run ACC in User tools. Do Copy and all Print resolutions. If that does not help, replace the ITB.
    • Gift
      • Mar 2011
      • 2458
      Have you tried another/fresh stack of paper?
      • JonManchester
        Technician / Shop Manager
        • Aug 2013
        • 103
        I Second the ACC, I would thoroughly clean all the optics first then when you do an ACC place a few sheets of paper on top of the printout before you scan and you will see better results. Also check the PTR if its past yield i'd change it.
        Live for something or die for nothing.
        • Debs1964
          • Oct 2010
          • 1690
          Check the springs that tension the PTR towards the ITB, one of them may be out of position, otherwise it could the the pivot point of the transfer/separation casing.
          Have you checked the image on the belt, I'm guessing it's OK, that looks like PTR problem
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • impetus73
            • Mar 2012
            • 75
            When I get pale prints on those machines, and ACC fails because of it, I manually adds toner using SP 3015, you sometimes have to run it twice or more, to get it good.
            I suspect the cause of the decline, is the developer degrading over time. I almost never have to change dev on the MPC line of machines, and the few that gets pale, I just refresh with SP 3015.
            If all fails, replace the developer.
            • Zeldaman
              • Mar 2011
              • 946
              Hi there!
              Agree with Debs, check the PTR-casing. It gets "old" & cracks often.
              Greetings...
              • gear13z
                • Sep 2011
                • 68
                did you check your pump motor?
                .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
                • petermuylle
                  • Jul 2015
                  • 18
                  Originally posted by Zeldaman
                  Hi there!
                  Greetings...
                  You can easely check by pushing the duplexunit inwards while printing a test page. if it comes out good (or at least better) it's the ptr pressure.
