A1075 sc322
  • petrus
    • 155
    A1075 sc322
    is it a700 error code is the same with the A1075?
    my Aficio 1075 intermitently the error code of SC322 appears.
    after i turn off the machine and its work.
    Is it related to the laser unit?
  • blee
    • Aug 2025
    SC 322 is a laser sync error. But sometimes this is caused by dirty front door microswitches. Those switches are in line with the laser unit on the wiring diagram.
    • Ricoh-ono
      • 338
      Personal experience on this model says replace the laser. Front door switches are less likely to get dirty on this model compared to others.
      Do what you can, with what you have, where you are. ~Theodore Roosevelt
      • Star
        Ricoh Tech
        • 127
        Little laser sync detector board in laser unit. Can be accessed from the
        feed side of the machine. Take off the side cover(s). You should see it
        through one of the gaps in the frame. I've seen them get dusted with
        toner, sometimes arcing out.
        Regards
        • petrus
          • 155
          thanks 4 the suggestion star.
          • tonerjock
            sc322
            Definitly laser sync error had it in the past but if you still experience error after changing try the relay clutch as this error is also related to timing of laser to paper reg.
            • romnick
              • Aug 2008
              • 56
              I have the same problem now. Have anyone succeeded in solving this problem? Please let me know and please tell me the exact procedure what you've done.thank you.
              • _Brent_
                • Jul 2009
                • 39
                I would try changing the laser sync detector B1405301 or the polygon mirror motor AX060250, assuming that you have already cleaned the lenses, mirrors and detectors with a lint free cloth. Using a can of air to blow out these area is probably not a good idea.
