Ricoh Aficio SP C410 DN Manual force toner
  • marklk
    • Jul 2015
    • 11
    i have a problem with the black printing gray, we just replaced the black pcu a few weeks ago, it was fine now its printing light black again, is there a way to manually force toner to print 100% black again?
  • Zaxxon
    • 608
    Re: Ricoh Aficio SP C410 DN Manual force toner
    Broken sub-hopper or toner supply motor.
    Please start you post with brand, model, problem.
    • marklk
      • Jul 2015
      • 11
      Thanks for the reply, how can i tell which is the problem, when i open the right side the cylinders are all spinning, not sure where the sub-hopper is? Is there a way to manually force the black drum to take toner?
      • TonerMunkeh
        Professional Moron
        • 3865
        Lift the top cover. Cheat the switch with something small and heavy. Try and run the bottle motor in output mode. If it doesn't turn, the hopper auger is broken, the motor has failed or the IOB has failed.
        Hit it.
        • Iowatech
          Not a service manager
          • 3930
          Are you using Ricoh toner? Sometimes non OEM toner will work at first, and then unexpectedly start doing stupid and wrong things later.
          Something to think about.
          • marklk
            • Jul 2015
            • 11
            Thanks for the reply, the last toner set we bought was off ebay, and i believe were refills, the black shows almost empty when its actually full, probably the computer chip needs to be changed
            • marklk
              • Jul 2015
              • 11
              thanks for the reply, how do i run the bottle motor in output mode?
              • tonnerboy
                • May 2011
                • 212
                Check the spring in the toner supply tube
                • marklk
                  • Jul 2015
                  • 11
                  i did get it to start printing darker black by turning the bottle by hand , is it very hard to get to hopper auger or motor?
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Yes, it's a ball ache. I wouldn't recommend trying it yourself as you have to tear the living shit out of the machine. If you need this fault properly sorting with correct OEM parts, call a tech.
                    Hit it.
                    • marklk
                      • Jul 2015
                      • 11
                      thanks for all the help, im seeing an error code SC367, any ideas how to fix it and whats causing it?
                      • TonerMunkeh
                        Professional Moron
                        • 3865
                        The machine has noticed the toner concentration in the developer is too low. Now is the time to call a tech.
                        Hit it.
                        • marklk
                          • Jul 2015
                          • 11
                          sounds like it, ive also seen SC442, not sure what that is
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            Transfer belt contact mechanism error I think.
                            Hit it.
                            • marklk
                              • Jul 2015
                              • 11
                              Thanks for replys, is there a way in service mode to shut the SC error messages off?
