SC186-00 on Metis series - what I found today
  • Athlontini
    • Jun 2012
    • 269
    • 37365
    Re: SC186-00 on Metis series - what I found today
    Cleaning the glass has always been the first step in trouble shooting CIS and back side image quality on SPDF models. Also, depending on the model, clean the reference plate/roller for the CIS. I have seen machines with a roller where one of the roller springs has come off and caused side to side image variations.
    • tullio
      • Feb 2012
      • 268
      ricoh mp6001- sc186
      ricoh mp6001- sc186.
      Specifically, my symptom was this: Power machine on, J001 misfeed in ARDF. Open and close door, misfeed goes away and immediately returns. On the third time it pops the code.
      Service manual says for SC186:
        • 37365
        Metis is not covered in Goose's Guide. From Goose's Guide for the C6501/C7501 and the MP 9001:
        SC 186 CIS error Check and reseat cn210 and 220 on adf main pcb
        SC 186 CIS LED error - CIS defective
        SC 186 Harness from CN 210 to CIS pinched on frame ,repair and reroute.
        There are 3 cables connected to the CIS unit. The harnesses connected to cn 210 and cn 220 are the two smaller ones the go to the ADF main board. Inspect both them for damage and reconnect them at both ends. If both harnesses are good and reconnecting them does not clear the problem, the only other option is replacing the CIS unit. The one used for the C6501 and MP 4002 is a different part number and costs $1195.85 from Ricoh. I had one go out on a MP 9001 yesterday. Luckily I have a C6501 parts machine that I was able to take one from.
        • David NSW
          • Sep 2013
          • 6
          Just had this problem, went and checked CIS Glass in ADf, cleaned gunk off it and closed cover and the machine worked
