Ricoh aficio 2051 web motor
  • mkopoiuy
    • Mar 2008
    • 54
    [Electrical] Ricoh aficio 2051 web motor
    Please help this problem.
    Aficio 2051 fuser web motor doesn't turn.
  • Iowatech
    Not a service manager
    • 3930
    Re: Ricoh aficio 2051 web motor
    I can't see your machine, which is why I need to ask the following questions:
    How did you check the web motor's operation?
    What have you tried to fix this problem so far?
    Without that information, any quick guesses I would make (like make sure the motor is plugged in) could be a waste of time rather than helpful, and who wants that?
    • nmfaxman
      • 1702
      Put a mark on the gear with a Sharpie, then go into service mode and turn it on a few times.
      If the mark moves, it isn't the motor.
      Work smart, not hard.
      • mkopoiuy
        • Mar 2008
        • 54
        Thank you for your reply.
        I have 3 machine with same problem. motor cable connector plugged in from motor to main board terminal.
        any other I have to check out?
        • JonManchester
          Technician / Shop Manager
          • Aug 2013
          • 103
          First i would remove the web unit and check the orange press roller to see if the web is stuck. Then i would thoroughly inspect all of the gears that turn the web to see if any are broke. Then i would inspect the wire harness of the web motor for damage cause they do get pinched alot. then i would put a black sharpie mark on top of the used web roll then do the web motor output check at least 10 times to see if that mark moves if not replace web motor, AX04-0159. Good luck.
          Live for something or die for nothing.
          • mkopoiuy
            • Mar 2008
            • 54
            I got it.
            web motor problem I found now.
            thank you very much.
