cl7000 code sc195
  • tonerjock
    cl7000 code sc195
    Have a cl7000 that I need to change the destination to n/a and also change the language setting in sp mode.
    However entering sp mode will not allow me to change these parameters. I believe that there is another manufacturing way to enter sp mode.
    This machine had an engine reset done on it which casued the sc 195.
    Thanks in advance for your help
  • Star
    Ricoh Tech
    • 127
    Not sure if this will work, but you can try it:
    1- Front door open, machine off.
    2- Hold down job and down arrow while turning machine on.
    3- go to Engine (2).
    4- poke around in the 5???s (mode) to see if you can find anything.
    (Also double check to make sure serial number is entered while you are in there.)
    Regards
