Hello, I am a wholesaler and I have a couple LD 190's that are set up with user codes and I cannot seem to reset them. I went into sp and could not find a way to clear them. Anyone know what menu that is under or a way to bypass the user code. Any help would be much appreciated.
Lanier LD 190 User Code
Look around 7810 and you can clean the main code. That will let you go in and shut off the others.Bachelor of Science in Information Technology, Comptia A+, Comptia Network+ -
I think it's somewhere under user tools, system settings, administrator tools, maybe address book management.Don't take that toner with me!Comment
Got into address book management, but how do i disable the user code? It was at a school and there are like 1000 users on the machine. I would like to disable the user code. Thanks for your help.Comment
thats it.Attached FilessigpicWe can all Win, but at the end we all loose. Save the greyhoundComment
They may have moved the admin setting from 7-810, which is weird. It's been there for many years.
Anyway, now that you can access the key op setting, you should just be able to go into address book management and enable/disable the user codes with one button. The codes will still be in there, they just won't affect the machine usage.
I thought you could not access them at all (without having a key-op code.)
It should be on the same screen as user code management on-off.Bachelor of Science in Information Technology, Comptia A+, Comptia Network+Comment
If you press the user tools/counter button then press and hold the # key while you press the system settings button on the control panel, this will enable the factory reset on the system settings. You should get a confirmation something like "are you sure yes/no." This should reset the user codes back to the default setting of off.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
