MP 2501 Faint copies after new drum and developer.urgent
  • tullio
    • Feb 2012
    • 268
    Hi. I am problems with Aficio mp2501 sp machines. I have changed replaced drum and developer but the copies are coming out faint. Even on a print out. I have initialised I.D. sensor and developer but to no avail. The funny thing is that the same developer works well on brand new machines. Please help
  • allan
    RTFM!!
    • 5462
    Re: MP 2501 Faint copies after new drum and developer.urgent
    Did you check for transfer problems?
    Whatever
    • tullio
      • Feb 2012
      • 268
      Yes.
      • TonerMunkeh
        Professional Moron
        • 3865
        Are you using the proper developer type for this model?
        Hit it.
        • copyaction
          • Oct 2007
          • 991
          are the mixing gears in the developer unit worn out?
          • lukeh
            • Jun 2012
            • 43
            Check lazer slit glass
            Sent from my GT-P5220 using Tapatalk
              • 37641
              Is only copying or are prints also light? If it is not used as a printer, are internal prints such as counter sheet light?
              • tullio
                • Feb 2012
                • 268
                printer and copy.
                • tullio
                  • Feb 2012
                  • 268
                  Same problem
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Are you using OEM toner and the correct developer for the model?
                    Hit it.
                    • sandmanmac
                      • 3990
                      It was never indicated by the original post whether it was the same 'faint copies' before the replacement of drum and dev?
                      It was never mentioned whether or not the drum/dev had run to cycle or had failed prematurely?
                      It was never answered if the gears are all in good condition.
                      He never answered if slit glass was checked, or the two times he was asked about proper dev? toner?
                      All he gives is 2 word answers or NONE at all!
                      Good Luck
                      • Wild Bill
                        • Jul 2005
                        • 774
                        I know this is an old thread but Id like to know what fixed this.
                        Generic Drum?
                        Izzy
                        • vargue
                          • Oct 2011
                          • 404
                          ok i met this before some type of developer not adapted with machine we make mixed form developer from other used machine but we be certain that is good contrast. after that yo will see image like a bullet . problem in developer may be fake or may be not convenient
                          • Wild Bill
                            • Jul 2005
                            • 774
                            Thanks that's what I thought it was...HUH???
                            Izzy
                            • StephenB
                              • Aug 2015
                              • 246
                              Generic Drum?
                              Had this same problem with the MP 2501. You must use OEM developer and especially OEM drum.
                              Also be careful with the fuser, use OEM upper and lower rollers.
                              And finally, the adf, use oem sep tire.
                              Good luck
