Ricoh Aficio SP C410dn
  • biznisse
    Spot like impression marks (physically speaking ca. 1/10 of a mm deep and 2mm wide) starts to turn up
    in the print, mostly at the top of the print but also randomly scattered through out the print.
    Status on all units show ok and more than 50% life.
    Beside this the printer works just fine.
    Greateful for any help on this issue!
    • 37490
    Re: Ricoh Aficio SP C410dn
    Samples and meter readings?
    • biznisse
      Thank you Sir,
      see attached files.
        • 37490
        My guess would be contamination either on the back of the ITB or on the roller that the ITB goes around at the PTR. This is based on the fact that it appears to be all colors. If it was only one color, I would look at the drum transfer for that color.
        • biznisse
          Thank's a lot!
          I will check this out.
          Cheers
