ricoh mpc 4000 fax forwarding...
  • n25an
    • 1030
    Ok... I know you can fax forward and i know how to set that up...
    ok... I know how to fax forward and print what is forwarded...
    does anyone know how to fax forward but if that errors out then the machine prints the document it was trying to forward...????
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • petermuylle
    • Jul 2015
    • 18
    Re: ricoh mpc 4000 fax forwarding...
    I dont know if that is even an option. When the forward fails the machine gives a 'Network Error' in the fax function, and stores the fax in the memory.
    It can be retreived in the Web image monitor or user tools; but not automaticly.
      • 37490
      Only if you have it set to save. Otherwise the default is to print any fax that fails to memory transfer, whether it is forward to folder or forward to email. This is so that no faxes are lost.
      • n25an
        • 1030
        ok so this is an automatic function meaning its the default... cool...
