help afficio650
  • etsmultan
    • Apr 2007
    • 131
    help afficio650
    i have afficio 650.it has code 496 which is held on copier i had clean the waste unit and rest the copier but problem remain same
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from JustManuals
    Paul@justmanuals.com
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      try to replace the toner waste motor.... check your sensor around waste.....
      fix the customer first then fix the machine... its simple and makes life more easy.
      • tonerjock
        Try cleaning the collection coil and piping from the toner recyling pump
        this can be a bit messy so make sure you have your vacuum.
        Also there is a small motor which coils toner into the bottle which has a sensor on it make sure the coil moves freely.
        • pspahr
          Toner Schlep
          • May 2008
          • 227
          Tonerjock is right....Pull the back off the machine and in the lower left quadrant (as viewing from the rear) you'll find the waste toner coil assembly. The coil that feeds waste toner directly to the bottle has a gear on a coil shaft with a spring holding it forward in the feed tube that empties to the bottle itself. When the bottle is full it backs up the coil and compresses the spring moving the entire shaft rearward. This action actuates the switch behind the shaft and gear assembly...........
          Anyway, try manually moving it in/out to free it up.
          VectorLinux---Check it out!
