How Can I installedRICOH MP-3053SP Printer Models With reahhat Linux 6
  • akram
    • Aug 2025
    [Misc] How Can I installedRICOH MP-3053SP Printer Models With reahhat Linux 6
    Dear All.
    I have facing problems to installing printer On Linux environment Ricoh Device Model : MP-3053 SP,OS: Redhat Linux Server 6,I want to describe the scenario for better understanding,
    a.I have Collect the Ricoh Unix Driver (r63122en) from Ricoh Support Website
    b.& Conform the connectivity from Redhat Linux Server PC by sbin /ifcofig or ping 192.168.0.10 ENTER it is successfully pining
    c. Systems--Administration---Printing (After authentications )---Network Printer---AppSocket/HP JetDirect---Host Name (pinter IP Address)Port Number (default 9100)---Forward
    In this step i am stuck & not able to find out the mentioned Ricoh Model and its drivers ,but i have the Ricoh Unix Driver(which is already Downloaded with me),Clearly to say that, I cant find out the HaveDisk (Windows Environment) options In linux Environment there is an PPD Post Script Printer Description but there is no PS options with this machine,i have tried with add printer from Server setting but problem is Same,
    So,Please anyone can help this issue? it will be very helpful for me,Thank You !
    Regards
    Akram
  • francisco
    • Nov 2009
    • 168
    Re: How Can I installedRICOH MP-3053SP Printer Models With reahhat Linux 6
    Originally posted by akram
    Dear All.
    Regards
    Akram
    you need to install the PS card option
    • pppp
      Technical specialist
      • Sep 2010
      • 43
      In fact I am fan of Debian distribution but issue should be the same. You have to use tool called CUPS
      Put into your web browser (eg. Firefox) "localhost:631" and then put login and password of user with admin (or root) privileges. You should be able to add and manage
      any printer with PCL or PS3 interpreter.
      Probably you have CUPS installed by default.
      Microsh.t is finished and Linux Rulez
      • pppp
        • Sep 2010
        • 43
        BTW. If your linux server has no GUI and you can operate only via console, the best way to configure CUPS is console (text) web browser (eg W3M or links2).
        Example:
        user@host:~$ links2 http://localhost:631
