Ricoh 3245c reg off and crooked copies/prints
  • nos
    • Nov 2008
    • 78
    i know it's an antique but the customer loves it. that said
    If registration is set at 0 the copies/prints are too far to the left (lead edge). if i max it out to 10 the copies/prints are just a bit over center to the right.
    Copies/prints are also crooked on the page. doesn't matter b&w or color or which drawer you pull from all the same
    Here's what i have done so far:
    cleaned transfer unit rollers and changed transfer belt
    change reg roller and reg sensor
    changed entire right hand door assembly
    changed reg clutch
    changed black dev clutch
    changed entire transfer unit with another one
    none of the above has helped. does anybody have any ideas on why it's doing this? i have no hair left to pull out. any and all help is much appreciated!
  • nmfaxman
    • 1702
    Re: Ricoh 3245c reg off and crooked copies/prints
    Press the */. to give you negative numbers.
    *3 give you -3 then # to lock it in.
      • 37491
      Have you checked the side fences in the paper tray? If someone tries to move the front fence without unlocking the rear fence it can break teeth on the fence rails.
      • nos
        • Nov 2008
        • 78
        i did check the trays and everything appeared to be ok. machine has three trays and lead edge reg is off in all of them. and they are all crooked. two have landscape letter and one has portrait
        • rthonpm
          • Aug 2007
          • 2854
          If the machine has its birth certificate tucked away, check what the registration values were on it from the factory. It may not also apply for single sided copies, but I always had issues with mylars in the inverter in this family causing skewed copies and jams.
            • 37491
            The terms portrait and landscape refer to the orientation of the image on the paper, not the orientation of the paper in the feed trays. Try using SEF for Short Edge Feed and LEF for Long Edge Feed.
            Check the amount of pressure at both ends of the registration roller. Uneven pressure will cause the paper to skew.
            • Iowatech
              Not a service manager
              • 3930
              I don't know if this will help, but if time permits you might try increasing the registration buckle and see what happens.
              • Zaxxon
                • 608
                I will add to this, print out the non default sp to see if anything is totally off track.
                Please start you post with brand, model, problem.
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  Is the problem linear when you reduce or enlarge. ie is the angle of skew the same ?
                  post a copy an a print to the forum.
                  • etep571190
                    • Oct 2009
                    • 21
                    First, induce a jam while the entire sheet of paper is on the transfer belt. You need to determine if it is a paper skew or not. The paper should be statically attached to the belt. If the paper is skewed there is a mechanical issue. I didn't see any mention of the bypass tray. Run it. The bypass has a different paper path and can help in narrowing down the location. Try inducing a jam while the paper is still in the reg roller. Skewed or not? These transfer units are know for having bearings inside the unit seize. This will cause various problems and swapping it with a used unit might not help you as they may both be bad (I've had this happen to me on one of these machines).
